Rav 4 Ecu Replacement
johnjames
can anyone tell me if i replace the brain on a 2001 2.0 petrol is it a straight swap or do i have to change the ignition or anything else as well.
Fitting of the part is a straight swap however you will need a master key to progamme the new ECU to the cars immobilser system and you will need a brand new ECU as a used one will be programmed to the car it came out of.
Is it not possible to clear the programming and start again? Probably a silly question but still worth asking.
