Brake Issues On 57 Plate Tourer
cattlegrid_79
Hi all
I recently started experiencing a judder when braking on my 57 plate D4D tourer. More pronounced at high speeds. Thinking this was an indication of needing new pads, I have changed these, however the issue still remains. The pads definitely needed changing anyway - as I realised when i took the old ones off.
Is this an indication I need new discs also or is this something else that needs looking into?
Any advice / experience appreciated.
Cheers
Almost deffo warped discs. If you can feel it thru the steering it'll be the fronts.
Thanks for your reply. Can't feel it massively through the steering, but you can feel it through the brake pedal quite pronounced - as I say, worse at speed so it's obviously a physical problem, rather than an ABS related type issue. Will try changing the discs and see if that solves it.
