Tns 200
jada71
Hi I am new to this forum, and I have just bought an Avensis Estate 2.0L 2002. I am having trouble with the TNS 200 sat nav. I cannot get the menu screen to move down to the set destination screen. It does the volume check but will not bring up any more screens and returns to the latitude, longitude GPS screen. It is a type 3 audio system. There is a 1.4 disk in the sat nav unit. Any help would be much appreciated.
jada71
Are you only pressing the "pty menu" button once? if you press it again it should scroll to the next set of options and one of those will be the destination choices.
Hi Penfold
Thanks for your quick reply. I did what you suggested and pressed the menu button ( < ) twice but it just returns to GPS screen. Whatever I try it will not move down the navigation screen past volume.
What do you mean by "pty menu"?
jada71
Figured out the sat nav, seems to work ok.
jada71
