Lowering Springs
GT4 BOOSTER
I had mine lowered by 40mm, But i did try to get the jamex 35mm springs but you will find that they are very hard to get hold of, The suppliers in holland dont seem to understand the word URGENT.. i waited for 4 weeks before i decided to cancel the order and get different springs.
I bought some 35mm Jamex and fitted them and they knocked at the front. No idea why, couldn't cure it so I'm in the process of trying to get my money back. The rear springs were fine, but the fronts looked more like they'd been cut than just ones that would drop. I've now got Roc which are a 40mm drop, but if you stood one of the front springs next to a Jamex front it's two inches longer! I'd avoid the Jamex!
Of course, if you really want them you can have mine for £50...
what color are jamex , are they red , cos i had red ones on before and they didnt last 4 months before car bottomed out , they lost all there stiffness i found my suspension was 2 coils not all 6 or so .
hi
did the roc springs get rid of the knocking as mine still knock and their the tte ones
and do the use the standard shocks
ta
Had my girl lowered yesterday by 40mm using sachs springs (red) cost £125 for all four.
woooo hoooo.
I have GMAX springs and they knocked at the rear, fixed it by putting a length of reinforced tube on one of the lower coils, as the coils were causing the knocking. Car is quiet and handles excellent, looks so cool as it has that stance...
  • 5 years later...
Iv got fensport springs on mines , 35mm drop looks the nuts handles great and there also comfy after a 2 months bedding in time, there coupled with kyb shockys from http://www.buypartsby.co.uk/index.php
Kevstir
HI ya Mate...
is your kayaba the standard shocks or is it the shorter one to match with you fensport 35mm drop... ? cheers
Good chance Kev won't see this post as his last one was 2008 and this topic goes back to 2004.
He is regularly on CC--UK. Try your question there. I think after 6 years he still has the same car.
Hi ya Mate,
i know your post is a bit old but just want to ask info.. what spring did you put on and how many mm drop? did you change the stock shocks. If not, was there any trouble or was it fine? I'm going to lower mine to and need some info. Cheers mate..
Hi ya Mate,
He hasn't been on here for nearly four years!
Why not fit a set of TTE's?, they're designed to work in conjunction with the stock Dampers, and as a bonus are made by Eibach.
