Spare Key
Plumbob
Hi
I bought a 2004 RAV 4 5 door yesterday but it only has one key. Does anyone know the best place to get another which will do the same job as this one does i.e. 2 button transponder type and an idea of the cost..
Just joined the Toyota Club in the name of "Plumbob"
Thanks in anticipation. Sunday 29th June
Hi Plumbob, and a very warm welcome to the club.
At top right hand side of the page under your name where you signed in you will find a search box.Type in spare key RAV 4 and try the previous posts on that first.
Good luck and again welcome
Del
Hello - welcome to Toyota Owners Club
A Toyota dealer would charge around £150 for a 2 button key including programming. You can buy a new non-Toyota key for around £30 then £30 - £40 to programme. A second hand key could also be reprogrammed but given the age, theres some risk. You can actually programme the key yourself or a Toyota dealer or auto-locksmith can do this. It can turn out very expensive if you loose your only key since this would require the locking module to be replaced.
