Running On 3 Cylinders , Injector Moving
andye
Hi all . My 2006 2.2 d4d has suddenly dropped onto 3 cylinders . Fuel and exhaust fumes are coming out from number injector 2 and the injector is moving , has anyone had this problem. ... looks expensive :-):-):-):-):-)
Your Injector is held in place by a two fingered clamp, these have been know to snap especially if the engine/injector has been worked on. To access the injector clamp you will have to remove the rocker cover, you will need new seals for the rocker cover, injector and a new clamp, whilst you are in there it might pay to do all four as a precaution.
Thanks for that, might not be so bad . .... looked terminal at first ... had it towed away this morning , just waiting for call from garage .
Got car back today . Had snapped an injector clamp , as thought , now seems fine ... does any one know if this is a common problem ?
I had one that loosed off the clamp - the clamping bolt worked loose.
There's details in the thread, Injector Problem http://www.toyotaownersclub.com/forums/topic/112796-injector-problem/
Not the end of the world - a little bit labour intensive - although the report that the clamp arms have been known to snap leaves me a little nervous.... :ermm:
My local diesel specialist keeps them in stock , so might suggest its common problem .
