Spare Wheel For Rav4 T180
Chadwick1590
WOULD A TOYOTA LUCIDA ESTIMA SPACE SAVER FIT
As it has the same pcd as I was thinking of putting it in the boot on long trips
Sent from my iPhone using Toyota OC
Not easy to check unless you have the wheel to hand. As well as the PCD, you'd need to check the overall diameter and offset so that the tyre didn't foul and was central. Additionally, you'd need to check that the dish didn't foul the brake calliper.
