2004 Avensis Lower Suspension
Looking for the part numbers of the front lower suspension bolts and the torque values. Do you have to carry out an alignment check after changing arms and ball joints.
Regards
Mod edit - shouting removed.
Hello Colin - welcome to Toyota Owners Club.
Have a look at these thread,
http://www.toyotaownersclub.com/forums/topic/160811-replacing-nearside-shock-absorber/
post 5.
also see attached.
43330S - NUT (FOR FRONT LOWER BALL JOINT RH)
90178-W0037 x2
43340G - NUT (FOR FRONT LOWER BALL JOINT LH)
90178-W0037 x2
43330M - BOLT (FOR FRONT LOWER BALL JOINT RH)
90105-W0067
43340C - BOLT (FOR FRONT LOWER BALL JOINT LH)
90105-W0067
Hope this helps, I have noticed that the genuine ball joints do not come with new bolts and nuts, it only came with the crown/castle nut and the pin at the top,
all the aftermarket come with new bolts and nuts.
post-125194-0-81800800-1404315366_thumb.
