2004 1Cd-Ftv D4D Engine Noise When Cold
avensisd4d786
I think the rav4 is the 114bhp, although the only difference I can find is that the Rav has an intercooler. The turbo ect. all look to be the same. Maybe someone on here can confirm?
I can now confirm they are totally different apart from the block!
Even the flywheel, crankshaft pulley and pipework is completely different. Ah well, will swap head over but will then need to change injector seals. Does anyone know which injector seals need changing (copper/aluminium/o rings) or do I have to do all of them? If so where can I get them other than Toyota?
