Click Sound
buklau111
Hi, wanted to know when turning in any direction, nearly full round does anyone else get a click sound? It sounds like a click when you click a mouse just once? If its a problem what is it and will it be covered under warranty? 2011 auris if it helps. On YouTube ive seen click/clonk sounds but it sounds nothing like them.
i had the very same problem/sound a few years ago on my 2008 auris they replaced the steering column under warranty. initially they fitted some sort of small part to the original steering column and after i complained that the noise was still there the whole column was swapped free of charge which solved the problem
