White Smoke Help! Hilux 2.5D4D Single Cab
fpoptani
Hi Guys am new here and need some advice.
I have a 2008 Hilux 2.5 D4d with a 2kd engine.
Problems is the car is smoking. Smokies white and the lingering Type. It's worst when you rev the engine even if the engine has warmed up. Checked the oil filler cap and could not see the creamy stuff. Coolant expansion tank is fine as we'll with no discolouration of the coolant. The car drives fine as I don't notice any power loss. No warning lights on the dash. Car has had regular service and it's only done 37k miles.
Any suggestions what it might be and what I should do to diagnose the problem.
Any advice will be much appreciated.
