Parrot Ck3000 Installation Issues
Trampeklapp
Just installed a parrot ck3000 in my 2004 avensis.
When making a call I can hear the person on the other end very good, but he can't hear me. He only hears a lot of noise, like something is interfering the line. I have placed the blue box as far away from the radio as possible. Any ideas what I have done wrong ( cause I'm sure I'm to blame for this...)?
Hi Morten.
Can I assume you have rechecked the connections, especially the microphone to the control box?
When I installed my very similar Novero system, I did a few tests before closing up.
So long as you use the correct adaptor cables where needed, everything is just plugged together.
I can only think that the microphone is either not plugged into the control box properly, or it and /or the control box is faulty.
Try pairing another mobile to eliminate the phone you are using.
Hopefully it is something simple.
Konrad
Figured it out. Must have been the mic connection. I'm so happy!
