When removing the standard dump valve it leaves a huge hole in the pipe. What do I need to do to cover this hole?? Also what would be the best valve to use?
I'm assuming you are still running the stock efi pipe?
You can you the stock dumpvalve to block the hole with some glue and stuff as below:
That way the breather can still be connected and the hole is stuffed.
A9903523-BA60-4129-8CDA-A65D2E633860-160
