Hi New To This Just Bought A Surf 2.4D Ssrx
Tezzla
Hi bought this surf put new batteries in and a hole lot of warning lights have come on fuel filter, Battery, timing belt, at/p, and oil pressure, does this just need resetting thanks
Hi, Welcome to the club... Enjoy :driving:
Remove the earth strap for an hour then reconnect and the ECU should reset.
Hello Terry - welcome to Toyota Owners Club
Hi thanks Raistlin will try that and thanks for the welcome
Sent from my iPhone using Toyota OC
Hi Terry,
If the ECU reset fails, make sure you have connected the
batteries correctly, then have the alternator checked, it's
the usual light display for a fail.
Hope this helps.
Gman.
Lights have gone out now apart from an amber T-belt one any idea
You need to find out when the timing belt was last changed,
the light comes on for every 60,000mls/100,000kms, If you're
not sure, have it changed, and change the tensioner,and idler
pulley as well.
Gman.
Yeah it's nearly 60000 miles so will do thanks
While the cover is off, change the water pump as well
it will save a lot of bother, not high milers those pumps.
Gman.
Hi all just been out car started fist time stopped for fuel then nowt called rac alternator shot so time to save thanks for the help before hand
Try here, they are not cheap, but new.
http://www.roughtrax4x4.com/?doc=11&cid=609
Or here, for secondhand parts.
http://jap4x4parts.com/
I have used both on occasions with no probs.
Hope this helps.
Try this other forum. It's great for info.
http://www.hiluxsurf.co.uk/
Gman.
