How To Check For Resistance
waqar_lionheart
Hi All,
Does anyone know how to check for resistance on my camshaft position sensor? I have a multimeter to help me measure it. Thanks in advance.
Regards,
Waqar
Instructions
Unplug the electrical connector from the end of the sensor and remove the sensor. Consult your service manual for the exact procedures specific to your car as they vary from car to car. The typical camshaft position sensor is a cylindrical-shaped device, about 3 inches long and installed in the side of the engine block. The sensor must be removed for resistance testing with a multimeter.
Test for resistance by setting the multimeter to ohms and touching the two probes of the meter to the two pins in the electrical socket on the sensor. If resistance is infinite or 0 ohms, replace the sensor. Infinite resistance indicates an open circuit in the sensor, and 0 ohms indicates a shorted coil in the sensor.
Compare resistance measurements other than 0 ohms and infinite to the specifications for the sensor in the service manual. Replace the sensor if it does not fall within the specified range indicated in the service manual.
Cheers Raistlin,
I shall be doing that soon as 2 weeks ago i took the sensor out but couldnt check resistance then. With my pinking issue I am going explore all areas.
Regards,
Waqar
