Crunching 2Nd Gear
dazayit
Only had it week, 08 1.3 yaris sr manual 24k on the clock.
Gear crunch from 1st to 2nd is this common should I get it sorted (im sure would be covered un warranty)
This only happens from 1st to 2nd all other gear fine
In my opinion it is normal.
There is a fix which helps, I had mine done under warranty.
You can change the oil..in the gearbox..Redline MTL, Castrol SMS-X or Motul 75W90.
I used Castrol... Made a difference..1.4 litres or summat required for a 2005 model so yours should be little different.. Not cheap at around £12/litre but worthwhile.
there is a modified gear shaft for that model and i would put toyota 75 gear oil in not 75/90 its to thick
mine is worse from cold but never really cures itself
