Leaking Sump Gasket
simz57
Hi all, ive got an avensis 2.0ltr 2002, it has developed a leak from around the sump gasket.
do I need to remove the longtidudinal brace underneath as it says in the haynes manual, or can I get away with just disconnecting the exhaust downpipe and dropping the sump and redoing the seal?
thanx si.
You can do it your way be it could be messier ...
