02.avensis Gs All Panel Gages When Driving Flicker Back And Forwards
bluegoa123goat
When driving up to twenty miles all the panel instruments flicker backwoods and forwards which is annoying i hope someone is able to help.Brian
Sounds like Battery fault, have it tested if its not that then it could be the alternator.
Could also just be a bad connection to the instrument cluster. I had this on my old Jeep. I removed the cluster, gently twisted all the pins in the plug so they were at a slight angle (to improve the connection) and put it all back together again with a squirt of WD40. Worked perfectly from then on.
