Mystery
kawakev
Hi folks
Have a mystery for someone to try and solve. Yesterday for some reason the vsc light came on, then my clock went back to one oclock.reset clock but when I turned off the ignition then on again the clock was at 1 oclock again. I had heard somewhere to try a reset by disconnecting the Battery. This I did but to no avail. Now to make it worse the central locking does not work or my alarm. The car starts ok.Ps I had the brake pads and rear spring changed 10 days ago.
Any help would be appreciated.
Check for stored fault codes. Check also that the Battery terminals are clean and tight.
