Egr Problem Posts
bobkneale
I was wondering if a website admin could quickly evaluate the number of posts related to the EGR valve issue and perhaps link them all together.
I don't wish to be hypersensitive or paranoid to the EGR valve issue, however it would a least put everything in one place !
Positive Regards, Bob
Not as straightforward as it sounds. Using the search facility calls up any topic where any of the words used in the search criteria are included. For example searching for 'egr problem' calls up 2,260 results across the clubs.
Hi, I thought you might say that, well that shows that EGR issues are common, however this is a specific EGR issue related to the Early IQ's only that have a specific Toyota design fault. We know it's a design fault because of the modifications required to correct it.
If you can do anything with all the EGR IQ posts it could help.
Positive Regards, Bob.
I've pinned the main 'EGR problem' post to the start of the IQ club - which is the most straightforward way of drawing people's attention to the issue.
Thanks !
