Electric Windows
dianadonoghue
I have a toyota hiace import r reg i was out in it yesterday and had my windows down went to put them back up and the two front passenger windows and the sunroof will not come back up.The electrics in the car are fine as the cigarette lighter radio and inside lights are all working has this ever happened to anyone's car i have had it in the garage and they have checked most fuses and they are fine does anyone know the location for the electrics for the windows or give me any advice on whats went wrong thanks.
Depending on your spec there should be 2 or 4 window switches 1 lock unlock button a 1 small square "window lock" if this is pressed it will stop the windows from operating, check this switch and try again.
