Problem P1215 Toyota Dyna
Johnny Karlsen
I have a problem wíth my Toyota Dyna 2002 d4d. It con not run below 3000 RPM. If you start it, it will stop after 5 seconds, unless you speed it up to 3000 RPM.
It has a fault: P1215
I've tried everything! Can anyone help me please?
P1215- cyl 3 fuel inj circ short to B+
Run a resistance check on injecter #3. should be something like 15-20 ohms, or at least in the neighborhood. Better yet check a few others you might be able to get at, just be sure there's no way to mix up the connecters. If # 3 is different from the others you found your issue
  • 4 weeks later...
