2009 Rav4 Sunroof Noise?
RavNI
Hi folks, our wee rav seems to have a noise coming from the sunroof like a small metal rod tapping when it's going over rough ground. Does anyone else do d this an issue and if so is there a solution :-)
Moved to the Rav 4 club
Ensure that the track is cleaned and lightly lubricated with WD40 - the roof can creak if it's not completely free moving. The wind deflector that springs up when the roof is opened can rattle - use a couple of pieces of thin adhesive foam to pad it.
Thanks for replying, I will give it a go tomorrow and post back the results.
