Aircon Light Flashing
jaybird1
Toyota d4d liftback Mar 2002. I have had the aircon recharged and it was functioning correctly for a while. The aircon indicator light started to flash, so I thought, pollen filters, Eurocar parts had them. Ordered them only to find out that they only stocked filters for a left hand drive, of which I made them aware and still await an answer despite acknowledgement of the fact.Next step wash/clean the originals which proved successful, no longer clogged, light still flashing though. Thought the worse, aircon pump etc. Then Eureka, flashback to electrical faults over the years. Dry connection. Disconnected multi plug at radiator, sprayed WD40, hey presto problem solved. Thought this may be of interest to ther members :clap:
Thanks for sharing,
Konrad has this problem with his, your best to go Mr T for this part. Blueprint do one part number is ADT32516 see if your local motor factors can get you one.but I would get them to order it first before you pay and explain the situation just incase the blueprint is for the LHD avensis.
Thanks for sharing,
Good answer.
Somebody on the forum has said that they bought a set of LHD filters from Eurocarparts, and cut the tabs to make them fit. I have stuck with genuine filters, but they do seem to last a long time with clean.
Clive, your fix regarding the air-con is great! Well done.
