Headgasket Probs !
gazkin
hi all first post to the forum, i own a 2007 avensis 2.2 d4d tr disel ,i dont know engine model.......
symptoms,,, drinking water,sometimes nearly 2ltrs, temp gauge just under half way, fan comes on just after starting,white water marks under bonett,and round rad pipes,lefthand side engine top,side....no water or white smoke from exhaust, no contaminatoin in oil dipstick,fillercap, or sludge in expansion tank,,,.......got it booked in friday toyota northampton, ,,,, not looking forward to that, :dontgetit::giljotiini: oh 117000, on clock thx all :ermm:
Hello Gareth - welcome to Toyota Owners Club.
There is a goodwill warranty on these engines regarding head gasket failure, but coverage is 7 years or 111,846 miles (180,000km), whichever occurs first - see http://www.toyotaownersclub.com/forums/topic/132178-charliefarlies-guide-to-the-toyota-2ad-diesel-engine-and-its-issues/
thx frostyballs ,looking like i`ve s...t it then i know i`m just out of warranty 128.900 :disgust::giljotiini:
Have you checked all of the cooling system, including the radiator for leaks?. Is the expansion tank cap seal ok? I had to change the rad. on my Avensis at about 120k. Simple job. Have you checked in the car matwells for damp/water ?
thx jaybird 1, someone did suggest tank cap, hope its that, will check carpets wen other half bk from work, heres hoping its one of the two you mention , if it is cap would that cause it to boil out of overflow , onto fan an spit water on to inside bonnet above tank area ?
Take it to a reputable garage Gareth and tell them you need a sniff test doing,or purchase a kit from eBay and do it your self...
http://www.ebay.co.uk/itm/FX-53-HEAD-GASKET-BLOCK-COMBUSTION-LEAK-TESTER-KIT-PETROL-DIESEL-100ml-FLUID-/281329478838?pt=UK_Diagnostic_Tools_Equipment&hash=item41808b2cb6
This will confirm whether or not the gasket is Fubared.
