How To Remove Lower Door Frame Trim
Paul99
How do you remove the trim on the bottom part of the door frame, this is the piece that has a shiny metal plate on it stamped 'Avensis'?
Should have made this clearer, its the plastic trim that the 'Avensis' plate is attached to that I need to remove, not just the shiny metal plate.
Paul
There are no bolts showing on the trim, only one clamp on the rear. hope this helps.
post-125194-0-87932600-1406824102_thumb.
