Usb Problems
ToyotaAuris
Hi guys, just used my Auris's USB for the first time and not impressed! I put in about 12 songs to test and when I played the songs they worked. But the problem is that when scrolling to the next song it takes about 15-20 seconds.... It leaves a silence and thats not good. Im not sure why, does anyone else have this problem?
The next thing is that I get error 6 after a song has finished playing and is searching for a new song or I scroll through alot of songs... Not good.
I currently use an 8gb nano stick in my USB with 60+ complete albums on - no delays in moving from one track to another, slight delay in moving from one album to another (no more than 5 seconds or so), and no error messages when searching for the next track.
Also use a Samsung Galaxy Android wifi mp3 player in the Aux socket - no problem.
oh ok, i dident have them inside a folder, i will put into them into a folder and get back to you.
If that doesn't work, make sure it's a USB2 stick and format it as FAT32. If you find that certain file types are causing problems, you could try converting them to another type, MP3's usually seem to work with most devices, WMA's are a pain in the neck.
