New With A Rav4 02
Grantstew8
Hi
I'm new and have found this site useful as I'm starting to sort out my own car rather than take it to the garage.
So far I've changed a rear wheel bearing, disks, pads and handbrake pads.
That is where I'm struggling a little, from reading the forum, I'm not alone.
The brakes seem to grab and I've done and changed everything except the cables. Next job is to do that, so I need a haynes manual.
I notice there were some posts about the hand brake positioning springs and needing bionic fingers to compress them and put on the cap....I've come up with a neat solution that does not cost a fortune: itty bitty cable ties. I use two and compress the spring completely, I can then use the tail of the cable tie to hold the spring in position too. Once the cap is on and in the "locked" position, use a knife to cut the plastic and pull out the bits. I'll take a photo....
Thanks for the help folks.
Grant
Hello Grant - welcome to Toyota Owners Club
