Any Bled The Brakes On An Avensis 2006/ 2008 2.0 D4D
borderman
I have the 2.0 model d4d that as got vlc braking the brakes need a complete fluid change , whats the safest way to do this or is it recommend getting them done at toyota .I have bleeded brakes on other cars useing the easybleed but I'm very nervous in doing this car as I don't want to throw up any codes or damage the vlc module or braking system as it's supposed to be expensive to replace if done wrong any one got views on completing this without damaging or causing air locks in the breaking system.
As you are not sure the safest way would be to get a competent mechanic to do it for you, it doesn't have to be a Toyota Dealer any good garage will be able to do it.
a brake fluid change at a Toyota dealer is £39.
(btw what are vlc brakes?)
