Replacement Headlight. Help!
mudinuri
Hi all,
I started a new thread today about fitting Spotlights because my headlights were so bad, but I have only just realised that the Drivers side headlight fitting is broken on my1998 RAV4 3 Door which could account for the bad lighting because the beam is shining slightly to the right.
Looking at the unit from the front the top left corner white plastic fitting is completely broken off so it looks like I"m going to need to buy a New/Secondhand Headlamp unit.
Does anyone have one for sale? or does anyone know what Part Numbers I need?
I have seen a 1992 headlamp unit for sale on eBay, Do you know if this will fit? or is a 1998 headlamp unit different?
Any help would be appreciated. Please.
Hi all,
I have seen a 1992 headlamp unit for sale on ebay, Do you know if this will fit? or is a 1998 headlamp unit different?
Hi David,
confused by the ref. to a headlight on eBay from a 92, see link below
http://www.toyotaownersclub.com/forums/topic/91067-rav4-model-range/
think they ran from 94 -2000, hope this helps identify it
You'll usually find 2nd hand unit's on eBay and aftermarket units are available at around £75 each. At the risk of stating the obvious - LHD units often appear in the eBay listings so check this out before bidding.
