How To Remove A Door Panel (2001-2005 Rav4)
dogfish246
Hey guys,
This is my first post on the forum so I wanted to make it a post to help others out. Here is how to remove a door panel on a 2001-2005 Toyota RAV4 and fix the common door lock problem.
Let me know what you think!
Welcome to the forum. These Chris Fix videos on YouTube are excellent - there's loads of them and several of relevance to the Rav.
Brilliant -can this be moved to the pinned section?
You would have thought that technology would have got rid of the black gungy stuff and easily torn sheeting .
Thanks man! I work hard to make these videos as helpful, concise, easy to follow, and simple as possible!
Thanks! I was surprised that they didnt have a better insulator but like any other car company, they take shortcuts so that it is cheaper for them.
  • 5 years later...
Thank you very much Mike for your help!
I had to give power straight to the right window motor so as to lift the co driver window that had been down since yesterday evening - I suppose because of the driver side multi switch failure.
Thanasis, Athens, Greece
