Auris Fog Lights
123pame
Hello dear friends.
I own a Toyota auris 07 model (the first one before facelift)
One fog bulb went off and I bought new ones (h11) but I cannot figure out how can I get into the bulbs to change it :\
Can you help me please?
Thank you in advance
Access to the fogs is a little more tricky than the other bulbs, but there is a plastic panel underneath the front at both sides which you could undo. The air box side (on a RHD diesel) can be reached from inside the engine bay, but you'll have to undo the air inlet pipe (one bolt). This will give you room to stick a hand down to the back of the foglight.
Hope that helps ! :)
I have 1.4 benzin (unfortunately....) i will look on it tommorow... I think i have to "park" the front reels on something to raise the front of the car a bit...
