Front Discs
pedro7680
Had the wheels off, im planning on changeing the discs and pads.
for a generation 5 the centre nut seems a funny shape.
is it simple or hard?
any one know if im likely to encounter any problems
theres 2 - 17 mm bolts at the rear of calliper and 2 - 14 mm bolts near them , take these out drop off caliper and disc should just fall off , if not whack it with a hammer , i think the nut you speak of is the end of the drive shaft ,which you dont need to touch. be carefull taking pads out though there's a few of clips , that sit them into calliper , i changed mine last week got pads and discs for £ 88 . easy job to do.
bit confused as to what ones im looking for for a 92 gen 5
FRONT DISC/DRUM - TOYOTA (90-94) CELICA ST182R/JT164 2.0 GT FWD
i'd say these £ 59 the pair - just call them up if ya want them .mine is a gen 6 1995 , st202 . they were asking £ 47 each local.
