Is It The Master Cylinder
Hello my 03 1.6 petrol verso t2 has a brake pedal that goes all the way down i,ve looked at all four brakes and can,t see any sign of leaks n not losing fluid also brake booster seems ok testing it by pushing on brake then starting engine n pedal goes down easier can it be my master cylinder if so is it easy to replace and roughly how much am i looking at for one. Many thanks Pad
I would say that it is definitely the master cylinder has gone t**s up.
Unless you are an experienced mechanic I say take it to the garage to be sorted, but get it lifted by trailer or recovery.
Do NOT drive it like that as you may lose all braking.
