Clicking Noise From Front
bags
so I'm out hunting in my 94 kzn130, encounter a bog went into 4H on the fly, no luck so reversed and went into 4L, still getting nowhere = winch time, SUCCESS. on other side back to 2H and hear this shocking clicking noise. put back in 4H and noise disappears. Got home and removed dust cap on hub and see that the cap which locks the wheel to the axle is free wheeling. purchased replacement axle and locking cap from wrecker for $125, 3 hours to fit and bob's your uncle. If you are ever needing to remove/replace your axle you will need to remove the knuckle from between the upper and lower suspension arms. I was told to pry the upper upwards to free the knuckle DON'T, the torsion bar provides far too much resistance and it is easier to unbolt the top of the shock and push the lower arm down. be careful the knuckle weighs around 20kg and if you drop it you will damage your brake line.
