A Newbie Question # 1&2
Vigo 2014
Hi everyone, sorry for negligence but since this the first time I have bought a diseal engine, I need some basic info. A mechanic told me that for diseal engine, whenever you start it after a while ( like in the morning) let it run idle for couple of minutes so the temperature gauge raises. Once raised, I can drive it. Is it true?
Secondly, is it difficult to start a diseal engine in winters? If yes than what precautions / tips should i keep in mind.
Yes, he is correct, like any engine on a cold day the lubricants are cold and less effective, let it run beofre you put the motor under any load. some diesels have an idle up button that you press and it raises the revs so the motor warms faster.
Secondly, Petrol engine main form of combustion is through spark and explosion of fuel, diesels work on compressoin. given this the amount of CCA or cold cranking amps your vehicle needs from the Battery is higher. it will state the CCA amps on the Battery so if you ever have to replace it ensure you get one with the manufacturers bare minimium, never hurts to get a higher rated Battery as you engine will start easier.
