Dash + Shift Lights Mod
Aidsy1
Finally got round to attempting to mod the dash+Shift lights on the dash, and have got fairly fair, may need to just fix some bits, but it is mostly working fully.
A little bit, i'll post some pictures in a bit. It isn't the best job, but it works
Well I study computing, so I just used knowledge gained from uni. And then I just tried it out.
Thanks :). As I said I just need to improve the design to have the LEDs working properly. Then should be good.
So here is the circuit diagram for the lights, its a very basic design, and sort of works, just need to figure out why the LEDs are always on, and then the shift light turns off the set of LEDS, although to be honest, I quite like the purple so will leave it at that.
post-130876-0-12771100-1411296196_thumb.
Honestly good job bud you have been wanting to do it for ages so nice one mate I'll pop over soon and check it out!
