Cargo / Boot / Trunk Light
JerWills
I've bought a 2012 Yaris and the light does not work in the boot/trunk (I assume the garage removed the bulb to save the Battery on the forecourt). I'm trying to remove the cover to have a look but can't see how it comes off. It looks very fragile so I don't want to force it... any tips please?
Small screwdriver gently inserted under one end of the cover should gently ease it off
If you are not confident to do this then why not pop back in to the supplying dealer and ask them to replace the missing bulb :)
I've tried the small screwdriver but the cover won't budge and looks like it will crack with any more force... has anyone tried doing this with a post 2011 (new shape) Yaris, as I think I might try and remove the cover that's below the light and try and pop it out from behind?
Why not go for the 2nd suggestion? Seems sound to me.
