Help!
breezer
Hi there, just gettin sum info on a new amp!!! Here is a description of a sony xplod one:
1000watts Max, 165 watts RMS x 2 at 4 ohms, 200 watts x 2 at 2 ohms, 400 watts x 1 bridged output at 4 ohms, stereo or bridged mono output, 4-ohm stable in bridged mode, Tri-Way capable, requires 4-gauge power and ground leads, MOSFET power supply and output stages, 50-300 Hz low-pass filter, 12 dB/octave, preamp- and speaker-level inputs, gold-plated connectors, variable bass boost (0-10 dB) centered at 40 Hz, 15-3/16"W x 2-1/4"H x 10-1/4"D.
I need an RMS of around 250-300. Im only powering a sub which is 300rms. Will this amp be suitable? I have no idea of this stuff,lol!!
itll run off one channel ok but be a bit laboured
i would bridge the two channels and run it like that as the amp would then be kicking 400rms and youll fry the sub after time
when you run one speaker of 2 channels
ie the +ve from one channel and the -ve from the other channel
ok! sounds simple but think il try and find an amp of around 250-300watts. Ne1 got ne recommendations that rnt too expensive!
2/1- channel amplifier, Maximum output power at 4 ohm: 2 x 200W or 1 x 600W. Rated output power at 4 ohm (RMS): 2 x 100W or 1 x 250W. variable low pass filter: 50-300Hz. Frequency response: 5-50,000Hz. MOSFET power supply. Bass boost: at 40Hz, 0-10dB. 2-ohm capable.
that be ok jaxx? lol
yeah that should do
id personal suggest an alpine mrd-m300, digital monoblock, great quality and sound, great little performer
These are only approx prices from places in Manchester, different places sell em at different prices
Alpine MRPT220 (250W @4Ohm Bridged) £100
Alpine MRDM300 (300W @2Ohm) £190 - Robs suggestion
Kenwood KAC8151D (300W @2Ohm) £175
Renegade REN480 (2 x 240W @4Ohm) £100
Vibe BlackBox II (300W @4Ohm) £195
Crunch MXB2125 (2 x 250W @ 2Ohm) £100
Crunch MXB2250 (2 x 250W @4Ohm) £130
Crunch V2600 (2 x 300W @4Ohm) £180
Crunch V2400 (2 x 300W @2Ohm) £160
Hifonics Warrior FALCON (280W @4Ohm) £160
Alpine MRPM200 (MAX 300W @2Ohm) £130
if you want to save on money then dont pay for the name, buy doing this could mean poor quality, if this isnt what you want then I'll dig deaper tomoz cos the shops are closed now
great quality, great sound..............nuff said
lol! shops in manchester aint gud 2 me! but il hava look round shops around here, cheaz :thumbsup:
I can nip down and post em to you
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
