Serpentine Belt For 2007 Auris T Spirit 1.6 Vvt-Im
patterct
Hi Guys
My first time on the forum...and need some advice. The serpentine belt on my Auris has snapped and disappeared somewhere on a local duel carriageway. I want to replace myself, but have had real trouble finding a belt diagram (so I know which pulleys need to be connected). Can any one advise whether I need the longer belt for the air conditioning or the shorter?
Equally where the automatic tension bolt is on the Auris...seen plenty U-Tube vids but none for the Auris.
Any help very much appreciated.
You will need the longer belt if you have AC part number 90916-02664 from your local Toyota dealer, tension is controlled by an adjuster on the alternator.
On a new belt correctly tensioned the:
Deflection of the belt between the alternator and crank should be between 7.5 and 8.6mm
Tension of the belt between crank and AC compressor should be 65 and 75 kg
post-45863-0-12290700-1410803125_thumb.p
