Dash Light
Kerby
i have just been readin your last topic, were u not on about the colours of ur digital display. im just on about changin the colour of the lights behind the buttons and the control knobs from green to blue
just look on the link there all on there
ummmm no........forgot!
ill check tho as im doin mine soon while the cars in bits!
dont use leds on dash. I have tried. you need bulbs or colored bulb covers. Now the bulbs have green cover and you can replace it or replace whole bulb.
Im having prob with that Ive blown loads of Blue LEDs, Ive even tryed using 2 470 Ohm resistors, oh and the stupid solder wont stick to the copper track, and Ive lost a BB, I think it was 3mm, does anyone know where I can get a replacement
What about the clock? Can the colour of the lights or bulb be changed on it?
Ill have a look at it, should be LEDs
the holo dash isnt hard its impossible!
you cant change the colour of it full stop unless you had a new one made!
the clock screen thing is also not possible as its a backlit LCD unit
ive seen a yaris one in purple an u need bulbcovers for changin lights in dash i cant find blue ones ne where
yeah I couldnt find any, was gonna colour them in with a marker
hi
in japan they do a multi colours unit for the speedo rev counter at a flick of a switch 8 differnt colours for the t sport....
Hi, Changing the clock/radio colour will be nigh-on impossible as it looks like it's a panel of EL (electro-luminescent) material like wot we use in one of our clocks. It will be totally built into the unit.
Cheers,
Alan
What if you coloured the face of the clock the colour you need, would that work? Maybe it would also dull the brightness of it!
