Tein Lowering Springs
Hazzard
Not me, I have Eibach.
Not heard of anyone using them on this forum either so probably not.
I'll do a Google for them now and see what they are like.
Craig.
Cheers Craig. been looking but no one looks like they have used them on a iq. What size wheel and tyres are you using with the Eibach if you don't mind
Just found the Tein website.
Look good, only for the 1.0, 3 cylinder models though by the looks of it and with a 35mm drop. The Eibach springs quote a 25mm drop front and 30mm rear so the Tein springs seem a bit more extreme. I haven't found any issues though with speed bumps or anything so can't imagine another 5mm will make all that much difference.
The wheels I have on my car are 7" wide by 17" diameter with an offset of ET42. Tyres are Toyo Proxes T1-R in 205/45 17 size and all seems to fit fine with no problems to report. :)
Craig.
Do springs make much of a difference to handling or are they more for the look? and does the ride become alot more crashy?
i've always found they have, as you have a lower centre of gravity and are stiffer springs than standard. coilovers are the best way if you really want better handling tho but not cheaper and i think only two company make them i think. bc racing and tein
I don't think he lowered springs are stiffer as in different spec of material than standard, just that they have less coils so have less give in them. I have the Eibach, same as Craig and I don't think they really make it much harsher. Just seems to tighten the suspension up a bit.
