Help Replaced Battery Now Car Won't Start
darsham228
Hi guys,
I have just had to replace my car Battery on my 2002 celica but now it won't start! I guessing it is the immobolizer cutting in and stopping it as ecu must of lost code! I only have one key its not keyless model just a normal key with unlock/lock buttons.
Does any one know how I can fix this as there is many things I have been told but most seam to be about adding a spear key not adding the normal key! car unlocks but alarm light just flashes fast continusley. am i done here as only have one key , but surely this key has correct codes as it never lost power the car did!
any idears guys
cheers Amy :dontgetit:
Mine is not the keyless entry as it a standed celica not the GT model
Linking your Key to car locks:
Better to start with confirmation mode first to know that how many keys are already programmed to it.
Here's the info (I have only tried and tested the "ADD" function) :
There are four different programming commands when setting up or verifying your remote transmitter, they are:
A. Add mode, used to add a remote to your Prius that is not currently registered.
B. Rewrite mode, used to erase all previously registered remotes and allow you to begin again the programming process.
C. Confirmation mode, used to verify the number of remotes that are already programmed in your Prius.
D. Prohibit mode, to prohibit all remotes from operating the door locks.
All four modes start with these instructions:
1) Make sure that the key is not in the ignition, the doors are unlocked, and the driver's door is open.
2) Very quickly, without turning, insert and remove key from the ignition twice. (leave key out)
3) Close and open the driver door twice. (leave door in open position)
4) Again, insert key into the ignition and remove it. This time only once. (leave key out)
5) Close and open the driver door twice, then close the door.
6) Insert key into the ignition and leave it in the LOCK position.
A. Add mode:
A1) Turn the key to "ON" for 1 second, then turn back to "LOCK".
A2) Remove the key.
A3) You’ll hear the doors "LOCK" and 1 second later "UNLOCK" (just listen)
A4) On your remote, press the lock and unlock buttons simultaneously for 1 to 1½ seconds, then let go.
A5) On your remote, IMMEDIATELY press unlock by itself.
A6) You’ll get one of three responses:
R1) You’ll hear the doors "LOCK", then "UNLOCK" once. The remote is accepted. If you want to program another remote, immediately proceed to step A4 with your second remote, otherwise open the driver’s door and the remote is registered.
R2) You’ll hear the doors "LOCK", then "UNLOCK" twice. Either you didn’t use the same remote in steps A4 and A5(not likely), or this remote was already registered.
The timing was off when you pressed the LOCK and UNLOCK buttons simultaneously and then UNLOCK by itself. Immediately press the two buttons together and the unlock by itself again. Keep trying until you get the locks to signal once that you have been successful. Then if you have another remote to program, quickly press its' buttons as before, until you hear the locks signal once. When you are finished, open and close the driver door to lock in the programming.
R3) If no response, go back to step 1 near the beginning of these instructions.
B. Rewrite mode:
B1) Turn the key to "ON" for 1 second, turn back to "LOCK" for 1 second, then back to "ON" for 1 second, and finally back to "LOCK" for 1 second
B2) Remove the key.
B3) You’ll hear the doors "LOCK", 1 second later "UNLOCK", 1 sec., "LOCK", 1 sec. "UNLOCK". (just listen)
B4) On your remote, press the lock and unlock buttons simultaneously for 1 to 1½ seconds, then let go.
B5) On your remote, IMMEDIATELY press unlock by itself.
B6) You’ll get one of three responses:
R1) You’ll hear the doors "LOCK", then "UNLOCK" once. The remote is accepted. If you want to program another remote, immediately proceed to step B4, otherwise open the driver’s door and the remote is registered.
R2) You’ll hear the doors "LOCK", then "UNLOCK" twice. You didn’t use the same remote in steps B4 and B5(not likely).
C. Confirmation mode:
C1) Turn the key in 1 to "ON" and back to "LOCK" in one second intervals for a total of 3 times.
C2) Remove the key.
C3) You’ll hear the doors "LOCK" and "UNLOCK" in 2 second intervals. (just listen and count each set)
1 Set = You have 1 remote registered
2 Sets = You have 2 remotes registered
3 Sets = You have 3 remotes registered
4 Sets = You have 4 remotes registered
5 Sets = You do NOT have any remotes registered
D. Prohibit mode:
D1) Turn the key to "ON" and back to "LOCK" in one second intervals a total of 5 times.
D2) Remove the key.
D3) You’ll hear the doors "LOCK", 1 second later "UNLOCK" 5 times. (just listen and count each set)
D4) This will erase all previously registered remotes and cancel the wireless door lock function.
Hi guys,
I have just had to replace my car battery on my 2002 celica but now it won't start! I guessing it is the immobolizer cutting in and stopping it as ecu must of lost code! I only have one key its not keyless model just a normal key with unlock/lock buttons.
any idears guys
The key I have is not a master key I don't think as it has not got toyota on it! and this is only key I have! is car buggered?? as am thinking will need to replace ecu with another from a scraped car with keys maybe!
I know a guy with a car Battery shop and he never actually disconnects the power supply when fitting new batteries by using a 3rd one.
Sorry mate you may have to play around a bit/spend money to get your car going.....modern day cars don't cope with 'Battery off, new one on', they need a constant power supply, i hope you get it sorted but again sorry i can't tell you how?
Mike.
Changing Battery doesn't do nothing to a celica, mine has been on and off plenty of times and never had this, it is as simple as old Battery off and new one on.
Only thing I can think of at the moment is you've either knocked something else loose, have a bad connection or you have blown a fuse/fried something electronic.
Unless immobiliser is buggered or you have an aftermarket alarm/immobiliser which didn't like the Battery changeover.
