Help! Bluetooth Fail!
jadecastles
Hi, new to club and excuse the sexism but am your typical female with not a lot of car knowledge or even common sense lol!
My bluetooth has just stopped working! I have a 63 plate auris icon. I've found bluetooth settings and it is showing as off, touch screen manual says I should just be able to press/select the on but it doesn't want to work!
Any ideas anyone?
Sent from my iPad using Toyota OC
I have the same car as you and I have just been checking.
Press SETUP then bluetooth then bluetooth DETAIL then bluetooth OFF OR ON.
I can find no other way of doing it,so if its faulty its off to the dealers.
The system might need a "reset".
