Toyota Celica 1.8 Sr (1998) Power Steering Oil?
Tumber07
Hey guys, Ive noticed that my power steering fluid is low, so much that it isnt reading dip stick.
Whats the best stuff to use to top it up?
I was looking at getting Wynns Power steering fluid?
Cheers
Dexron II or III Spec. ATF usually...make sure you ain't got a leak though.!
Neil
Check the Oil cooling pipe just behind ther bumper grille is not damaged, this could be where you are losing oil. The levels will change when the fluid is hot or cold.
