Passenger Airbag Switch
cats_123
Hi everyone, we've just bought a used yaris 2009. There is a warning light that says the passenger airbag is off. I've found the switch, but can anyone tell me if I need a special tool to turn the switch off? I don't want to force it.
thanks
No tools required, insert your car key into the switch twist and hold on the desired setting then pull out the key whilst holding in the desired position.
The time a passenger air bag should be switched off is when there is a baby seat fitted in the front passenger area.
But you probably knew that anyway.
