Bluetooth Media Very Quiet!
Portocksboy
I have a touch and go, but recently the volume level from my iPhone 4 music is much much lower. I cannot say whether it has to do with the iOS 8 upgrade or was there before. Even with the volume on the set at max it is hardly audible. I have deleted the music on my iPhone and reloaded it. I have also deleted the pairing and rest, to no avail? Any thoughts? Will check other forums.
Sent from my iPad using Toyota OC
MIne has always been so. NB have nexus 5, not iPhone. Crank up volume on TnG and it's audible.
Is the volume on your phone turned down as a low volume on the phone will result in a low volume through the headunit.
Quite possible that the iOS8 update is causing this if your phone volume is full. I use the usb to play music from my iPhone and since the iOS8 update it no longer works consistently. 8.0.3 should be released in a few weeks so maybe hang out for that and see if it improves.
