Ignition Coil
mr ben
Glad to hear it's repaired... :-)
In order to keep things "clean" I only use Shell V Power and also put in BG44 fuel system cleaner every 6 months.
If when you drive the vehicle and it jerks and cuts off its the fuel injector, if it stalls when the cars at idle its provbally not and its the ignition coil. Funny enough my old car vw had faulty ignition coil and then the mechanic put another ignition coil in the problem persited. The mechanic kept it over night and cleaned the throttle body and changed sparks but still nothing happen. Then the mechanics switched each igntion coil around, so same ignition coil but put into other cylinders and found that the ignition coil they had previously 'replaced' was faulty too.
