I dont know :censor: about brakes. But I know it is not normal when my brake pedal and steering wheel shake violently, while braking.
Yep.......that's not normal.
Sounds like you've got a warped disc on there.
Rich
wierd thing is i replaced my left rotor. but when i took off my wheel yesterday, I found two deep circular cuts that go around. Its like my pads are digging into my rotor.
u should have replaved ur pads and discs at the same time, ur pads are probably scorched from the old disks. Change ur other disk and buy a new set of pads, ul only spoil ur new disks if u use old pads
ill get right on that, after i get my wheel bearing and braking system fixed.
