Sr 1.6 Front Passenger Window Switch & Back Door Problems.
swanseaguy
Hi guys,
The front passenger door window switch decides when it wants to work or doesn't want to work. Sometimes when it is working the driver side switch for the passenger window decides not to work either.
I've recently bought the SR180 (wanted more power, loving it by the way) and took the passenger switch out of there and put it in 1.6 everything seems fine and it works lovely. So I've bought a new switch to put in the 1.6 passenger door.
This is where I need some advice. The back doors sometimes dont unlock and it takes some fiddling to allow it to unlock. Do you reckon I should change the entire switch system on the driver side as there could be a connection problem there as well relating to the back doors not unlocking?
Has this happened to anyone?
